MGB rear axle conversion to disc brakes?
I'm currently thinking of swapping out my shortened SD1 axle for an original MGB, but I don't want to run drun brakes. Has anyone converted such an axle to disc brakes, if so what did you use?
Re: MGB rear axle conversion to disc brakes?
chodjinn wrote:I'm currently thinking of swapping out my shortened SD1 axle for an original MGB, but I don't want to run drun brakes. Has anyone converted such an axle to disc brakes, if so what did you use?
Hi Dave,DaveEFI wrote:Thanks - must get round to fitting them to the actual car. No garage - so want a few days guaranteed good weather. Never happened last year.unstable load wrote:Neat work, Dave!
When you do fit them, switch the bleed nipple to the top outlet to assist bleeding.
They were probably oriented at 1 o'clock not 3 o'clock on the original car.
Regards Denis
Looks good, what calipers are they and what diameter/thickness disc are you running?DaveEFI wrote:chodjinn wrote:I'm currently thinking of swapping out my shortened SD1 axle for an original MGB, but I don't want to run drun brakes. Has anyone converted such an axle to disc brakes, if so what did you use?
