helpplease sierra t5 speedo drive will any other drive fit
sidewaysbo
Post by sidewaysbo »
does anybody know any other gearbox with similar complete speedo drive including alli bit that will fit in these t5 i got mechanical type clock not electric got to get this old car for the mot and need complete speedo drive thanks bo
mk1 escort v8 modified 4.6 ex hillclimb car been put back on the road with no frills just like me lol beausideways.17007@uploads.photobucket.com?subject=Mobile+Uploads
kokkolanpoika
Post by kokkolanpoika »
This is an electrical, but you can buy a mechanical for rimmerbros i think.
SD1 speedo sensor.
My box is Mustang T5, not sure for your´s
You have to grind carefully original teeth´s away, like i did.´And made a small speicer + O-ring to seal it. I use loctite to fit this speicer.
Uploaded with ImageShack.us
I use Ford mustang speedo sensor gear, it is not tight fit, or not too loose, but need to drill small hole + split pin..
Bolted together.
And you can use SD1 LT77 speedo sensor locking plate also.. Slightly grind it..
And i think summit racing will sell T5 mechanical speedo sensor also..?
http://www.summitracing.com/search/bran ... ed-sensors
I think SC46 will fit.. It has got both, mechanical and electrical for cruise etc..
Timo
sidewaysbo
thank you very much for the reply very helpful
thanks bo
Exactly what T5 do you have ? and did it originally use an electric sender or a cable output ?
