From cold it starts first time, every time, even after sitting idle over the winter layup. If I forget it's not an automatic and stall it, then it restarts without incident.
However, if I use the car on the school run or for some other relatively short journey it will not restart after sitting for 10 minutes or so. It cranks very slowly - well below what is needed to start the car. If I attempt to jump start it from a well charged battery, it does the same. If I use a running vehicle, it will restart, but it nearly sets fire to the jump leads.
I am a little confused by this behaviour - I have replaced all the electrical components, so am beginning to conclude there's an expansion problem somewhere in the engine - do piston rings seize up when the car isn't running?? (It's done 150k miles, so is allowed to be a bit ill)
All suggestions appreciated. (Specially if you can make the man-maths add up to building a silly spec engine with my overtime pay
