fuel pressure reg/filter king
Quick question,do I need to get the specific V8 model with 85mm bowl or just a normal 85mm bowl?
It's for my twin turbo rover v8
Cheers in advance.
Cheers in advance.
Just the 85mm bowl will be fine.
Running this on my cars http://www.burtonpower.com/filter-king- ... pr007.html
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
Building a GT40 mk2
If you are running a twin turbo set up then you need a boost reference type regulator. Otherwise the fuel flow will reduce as the boost rises and if the boost is high enough it will reach a point where it will start to flow back to the tank.
To get a better answer you need to state the fuel pump type and if it's a carbs or injection set up.
Regards Denis
Regards Denis
