OMVL single port
OMVL single port
OMVL single port set up on my 90 v8 all works with out any problems only thing is the safety relay got removed when i changed over engines, does any one know how to wire it up? like i said its just a safty relay four wires and a bridge on it, any help be great,thanks mark.
If this is the relay you mean http://www.autogasshop.co.uk/safety-tim ... -382-p.asp.
Positive and earth are self explaining the 2v are the outputs to your solonoids and the right hand symbol bit like pye is signal from the coil. Usually this is a wire wrapped around the coil to dizzy ht lead.
The relay only stays energised while there is a signal from the ht lead to the relay.
Hope this makes sense mick
