How much tilt is permitted for a 302 + T5?
Im looking at having the driveshaft end of the gearbox about 1.5 inches below level when viewed from the side.
( engine is about .5" off level from one end of the rocker cover to the other end)
Fitting in TR6 V8
Ford 302 + T5 gearbox how much tilt is ok
The tilt is fine you can run engines at some crazy angles if needed, but, what you do need to take into account is the diff flange has to be a similar angle to the tailshaft flange to keep everything in Phase, it is sometimes desirable to run the dif slightly "nose"up so the flange is in phase when driven and under load, not when stationary,
