Exhaust maniflod gaskets.
Post by ian.stewart »
Im getting really p-ssed off with having to change exhaust manifold gaskets, primarly because they seem to leak after a few months, my engine is a fairly tight install and its about a 4 hour job per side, are there any alternatives to the composite sandwich things, Mine ate probably failing because I have to remove loads from them so they do not restrict the exhaust ports, I have seen some on Fleabay, they look a bit dubious in construction, but they may work????
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
anyone tried these????
Thats Bizzare Ian
I just popped into Real Steel today for a set of the ususal silver ones. And they offered me a heavy duty set like the ones in you picture. I got both sets just in case. The twin heavy duty ones look like card, but they do have a steel mesh inside. And they have much bigger holes. They were 10 quid for the set of 4.
POOH ------Guess where I was today, Looks like another trip round the M25 Carpark
plastic orange
Post by plastic orange »
I read somewhere (probably an American site) and they recommended using silicon sealer to seal the headers. I tried it in conjunction with the gaskets and it certainly helps and doesn't seem to burn off. My headers are pretty tight too, and it's a major job to get them off or on (have to remove rocker cover on 1 side).
Pete
Image Image
As ornage says, you can get a special high temp silicone. Its copper based, and isnt too bad at all.
That said, the head/flange interface will only really get as hot as the head itself, so normal silicone might be worth a try.
But more importantly. Make sure your flanges are 100% flat, and true.
Then just bolt it up with no gaskets. That way they wont blow out again...and no, Im not joking.
Thats the way I ended up running my TT, as no gaskets ever lasted more than a few weeks without blow outs.
Yes there were some minor leaks when cold, but once warmed up, it was fine.
n/a manifolds wount be subject to the same warpage as turbo manifolds though, so it should work much better.
i use normal silicone sealer on my exhaust joints and manifold gaskets for the past 3 yrs,
i was told about this by a fitter at the local exhaust center, makes taking system apart easier too,
Just got the bigger gaskets from RS, much better than the Steel composite, I have allways had to enlarge the ports on the composite ones, and have used ones from Pop Browns at £35 a set, I have assumed the gaskets have failed due to the reason being that the only way to trim the gaskets was with a wad punch and very sharp Chisel, and risk de-laminating the gaskets,
These new ones still will need a bit of porting but not much at all. and all for £10.71, Bargain :D
a thought just whizzed thru the brain, As RS never used to do these gaskets, I wonder if they are for their new Merlin Heads???
Yes, I like those gaskets from Real Steel, soft enough to be able to enlarge with a dremel and a burr + everything lines up far easier than the juggle with single ones, and I am trying Silicon as a sealer rather than that horrible ceramic exhaust paste,
I just found that they foul the head studs on a 14 bolt head so I had to trim them down a bit. I must say, they seem to be quite a sturdy gasket.
I'll have mine back in the bay tomorrow so I can see how the fit.
But they look pretty good at the moment.
done and running, no leaks, just a smear of silicon, and only 5 hours to get one set of 8 bolts done up, who said they will never distort :shock: :shock: but they are done up now, untill next time-------------------------------------------------
ihatesissycars
Post by ihatesissycars »
ian.stewart wrote:done and running, no leaks, just a smear of silicon, and only 5 hours to get one set of 8 bolts done up, who said they will never distort :shock: :shock: but they are done up now, untill next time-------------------------------------------------
Blimey, and i thought i had it bad with my setup!
Paul B
Post by Paul B »
stevieturbo wrote:As ornage says, you can get a special high temp silicone. Its copper based, and isnt too bad at all.
All silicone is virtually indestructible heat-wise. We use normal gasket silicon sealant on Caterpiller turbo manifolds, and they glow red sometimes.
I've even used it INSIDE exhaust header pipes on a motorcycle, to try and stop the chrome blueing where the pipe meets the cylinder head. A fingerfull was smeared as far inside the headers as you can reach. (not far with my pudgy fingers )
It didn't work, but the silicone was still stuck in there next time I took the pipes off.
I fitted mine yesterday with no sealant, and they seem fine so far with only an hour or so of running.
spartanv8
silicone
Post by spartanv8 »
Have I got this right? Just use silicon sealer and no gaskets? What sort of silicone sealer, the bathroom type?
Fil
If it's got booby bits or tires it's going to be trouble!
If you are using fabricated manifolds, I would say use gaskets, I am fairly certain the fastory cast iron manifolds never had gaskets, but sealed OK,
From experience, I use a sealant, Bathroom sealer will work, But I would use a RTV hi temp silicon which you should be able to get from any decent spares shop, I have also used with some success Blue Hylomar,
The one thing I do not like is the white exhaust assy paste, not only is it messy, its corrosive as well,
Ian :D
