CO and HC figures ?
CO and HC figures ?
Hi All, had a quick mess about last week with my mates exhaust gas analyser, it's a 3.5 with a hurricane cam, slightly ported heads, edelbrock 500 and manifold, i had initial reading of CO 0.5 and HC 400ppm, i took it out for a run and it changed to CO 2.5 and HC 280ppm, all done at idle, i was thinking the run cleared all the unburnt fuel out of the system? anyone else got figures from there mot? john
So thats where it went !
badger
HC most likely came down as a result of getting the internals fully up to running temp.
Typical figures I'd expect would be as follows:-
CO - 1.0 to 2.5%
HC - 650ppm maximum.
Ignition timing has a big effect on HC, weaker mixtures will reduce CO and HC (to a point where combustion becomes inefficient then HC will rise rapidly), richer mixtures give high CO and HC.
Anything less than 1.0% CO will give rise to very high exhaust valve temps and most likely a rough idle (remember, the fuelling with carbs is nowhere as precise as EFI and the rover V8 engine will become less tolerant of leaner mixtures when on carbs), anything over 3% CO is a waste of petrol, anything over 6% is risking "bore wash"! HC really ought to be anywhere below 600, the lower the better really!
I find that a smooth idle is easily achievable with a CO of around 1.75 to 2%.
CO - 1.0 to 2.5%
