Has anyone got any feedback on V8 tuner, ive seen this:
http://www.v8tuner.co.uk/product.php?id=874
Uses longer rod with pin higher up the piston, its either this or a will have to go stroker crank rods and pistons
V8 tuner parts
A while ago I built a short block 4.6 using Mustang modular overbore flat tops, made by Manley, they cost about £250 + rings, they use the same bore as the stock 4.6 and the pin sizes are slightly smaller so I had my rods bronze bushed. all seemed to work ok, you would need to check crown heights
