As I'm now used to the joys of fuel injection, I was considering ways of getting the period look with the running benifits of EFi. Flicking through one of my 'build your own EFi' books I stumbled across an article on converting a Dodge Challenger B-block using such a system - however as I read into it it became clear that Pro-Jection was more of a standalone thing.
A bit like this:
As they found some problems with it, they modified the system by welding injector bosses onto the manifold (as it was a single plane Edelbrock, with runners that are in line with eachother) and converted to an aftermarket ECU, utilising the Holley as a throttle butterfly.
I was just wondering if anyone had tried something along these lines - using a 4 barrel manifold, getting the bosses fitted to it and using a plain Holley or Carter AFB to control airflow, with a Megasquirt system controlling the fuelling.
This allows the use of period air filters and so on (like the yummy Cobra ones
Do you think there could be an improvement over the standard system here? If there is that chance - I'll get to it and pick up the appropriate bits!
(Then I can report back when it transpires to be exactly the same
I just stumbled across this as well :
http://www.barrygrant.com/bgfuel/default.aspx?page=63
But I'm not sure how you'd control something like that with Megasquirt, or wether you even could.
This is what I'm talkin about:
As much as I'd love to go turbocharged, I swear there just won't be the room so for the meantime I will look for ways to improve the flexibility and driveability of the existing lump as well as improving the looks
