3.5 v8 that kangeroos after about 30 miles.
Tank is new, fresh fuel
Line and filter are new
It's on a regulator at 2psi with a 2-3psi facet electric pump which is beneath the rear chassis. Ticks fine and pumps through to end of pipe at carb ok.
Wondered if it is electrical, something breaking down at higher revs or when warm
Engine temp says normal
Fan is not viscous but electric on a separate switch
Thought the coil was warm ish so I had a spare an swapped it and it made no difference
I drove to mot place about 20 miles away, they had it idling etc
Turned off for about 20mins to do paperwork
Got 16 miles home and she's stalling.
Did the same on the same journey a 2nd time but not as bad.
Carb is a 38dgas that came off a running car
Can't tell if thermostat is opening
Tank has a breather hose looped up and over an back below tank level and its clear of obstruction.
It's an sd1 dizzy with a recently new cap on it. It looks fine.
Leave vehicle to go fully cold at seems to be fine until it does it all again.
Any ideas where i can start looking to troubleshoot?
Richard
Richard
Genuine Landrover Cap or pattern?
If Pattern I think upi may have to buy a genuine one
Lots of info on here about pattern ones breaking down far too soon
its the dlm8 one from what i can tell looking at the pics of the types.
is is just worth replacing the bit on the side or go full package to something like
http://www.simonbbc.com/bundle-deals/v8 ... ition-coil
and add in
http://www.simonbbc.com/bundle-deals/el ... -red-rotor
and hope that this cures it?
the carb came off a running sd1 and i think the cap came from paddocks but can't really be sure.
and add in
The amp on the DLM tends to either work or not, in my experience of several failures. Although it can fail when hot, then work again after it cools. But not known one to cause a misfire.
I'd be wary about buying one of those new cheap repro dizzies, if the SD1 forum is anything to go by. In any case, it would probably be cheaper to overhaul the original - if it needs it.
One failure I had caused the engine to cut out completely. Leave it a while and it would start again - until the next time. The actual amp was oscillating when in this fault condition putting a series of spikes into the coil with the engine stopped. This might show as an AC voltage on a DVM at the coil negative with the engine stopped - it certainly showed on a 'scope.
Interestingly the failure I had with the DML8 was exactly as the OP describes - would just gradually run out of sparks. - Started with not enough puff to run 6 and 8 being the longest leads
I binned the whole thing - stripped out - removed and fixed baseplate and re-curved an old Opus type and fitted with a Lumi.
Andrew
Andrew
4.5L V8 Ginetta G27
