lpg injection- pressure in fuel rail
Quagmire
Post by Quagmire »
I need to decide on a pressure sensor to use in order to monitor gas pressure at the lpg injector rail and allow megasquirt to cut back to petrol when a lower threshold figure is reached.
Can anyone give me a rough idea of what pressures are normally seen on the vapour side? If Anyone knows what pressure causes theirs to cut back petrol that information would also be very useful!
[/u]
1974 Rover 3500s
1984 3.5 90
1959 2.25 series 2
badger
Post by badger »
The OMVL systems I install can be set to different pressures depending on application. 1.2 bar and 1.8 bar are, from memory, the two common settings.....
Badger.
www.roverv8engines.co.uk
Quagmire
Post by Quagmire »
1974 Rover 3500s
1984 3.5 90
1959 2.25 series 2
Return to “LPG Section”
