ZF HP22 Help to ID and find parts
beniboyz
Post by beniboyz »
I am hoping someone can help me with my ZF HP22 Gearbox. I will say that it is not fitted in a Sherpa, it was removed from a rotten riot van a few years ago (not by myself I might add).
The gearbox is being fitted to a 3.9 Disco engine and then into a Morris Marina coupe.
Anyway, could someone ID the top plastic connection on top of the tail housing? Is this a breather? How would it have been connected in the Van?
Second question: How dose the speedo cable work on the sherpa? Should there be a drive wheel inside the tail shaft? Can anyone help me find the right bits to make it work?
I really appreciate your help.
Regards,
Ben
JSF55
Post by JSF55 »
Hi, the first pic show the breather which should have a small clip on cao on top of it, either source one from another box, or do like i did and made a suitably sized pipe push on and dropped it down the side.
Not a clue on the speedo parts, altho an easy alternative would be too machine up a bung and go with a pick up of the prop or gps, john
So thats where it went !
bodger
Post by bodger »
Ben , think it would be best with a manual box ...lol
The outlet is a breather. I just left it as-is on my van.
The speedo drive is unique as far as I can tell. It's not available from ZF anymore, so basically block the hole off and use some kind of electronic pickup kit.
It's not the same as an LT77 drive.
Some light reading:
http://www.cowdery.org.uk/zf.php
beniboyz
Post by beniboyz »
bodger wrote:Ben , think it would be best with a manual box ...lol
I still might take you up on that if I don't get on with the ZF.
ChrisJC wrote:The outlet is a breather. I just left it as-is on my van.
Some light reading:
Thank you Chris. I think I will just do that.
Ben
