Will this work with a MS3
leylandracer
Post by leylandracer »
Any idea if this will work with my MS3? http://www.scangauge.com/products/scangaugeii/
Not sure that will connect as it uses proprietary connections but it might. What will work though is the MegaView II http://www.diyautotune.com/catalog/mega ... -p-96.html it will even let you change settings. Philip Ringwood (DAXtojeiro) might be able to do you one built if you wanted. He will be able to tell you if your ScanGuage will work as well.
Doubtful, it is an OBD based setup.
This could probably be configured though
http://www.ecudatascan.com/news/51-anal ... orted.html
