Land Rover 110 V8.Vibration.
I have a 110 V8 CSW.It has always had a vibration/coarseness through the driveline.It makes no difference whether in or out of gear[coasting].I have fitted new genuine props,good s/hand t/box/new cv joints/swivels,wheel bearings all to no avail.The gearbox is an LT85 and seems ok.Any suggestions as to the cause would be gratefully received.Nick
OK:
1. Try it with the transfer box in neutral
2. Remove a prop, and the drive flanges at that end. You might get a spot of grease coming out, but it will eliminate the prop / diff / halfshafts.
3. Can you get another set of wheels to try?
