A-frames
bones
A-frames
Post by bones »
Hi all, when it comes to towing with a-frames which are better for connecting. Ones with ratchet straps or chains ???? :? rich
JJMclure
Post by JJMclure »
I've only ever used ratchet straps and as long as the arms don't spread they work ok. I try to avoid using an a bar if possible!
don't nibble on the barrel, pull the trigger!
Permanent fixing to the car being towed.
So a horse shoe or U bracket welded to the front of the car being towed and a bushed end on the A frame.
A bolt through each with a locknut.
Then if you are really flash
Cut into the loom of the car being towed, and splice the rear lights to a quick disconnect connector near the radiator. 4 foot of wire from your tow car to the radiator of the one being towed and the brake indicators etc on the tow car work a treat!
kev_the_mole
Post by kev_the_mole »
I thought A-frames were only legal for recovery and not general towing???
What about the campers that tow a smart car?
So long as the car is road registered I can see no reason why it would not be legal????
When I made one years ago I made it ratchet straps on chains just to be awkward. If I was to redo it I would just make it ratchet straps as sometimes the chains are a pain and don't sit quite right.
Mine has ratchet straps and chains.
A mate has one that is able to adjust for width by means of a geared head section and the connection to the car is on the forward control arms by a hook and fork that has chains internally i the "legs", coming to a ratchet strap for tightening it all up.
I was really impressed with it.
bones
Post by bones »
Thanks for the replies all. Ordered a chain item with extended arms so as it fits my car. Thanks again :D rich
kev_the_mole wrote:I thought A-frames were only legal for recovery and not general towing???
Thats my understanding too.
Thats correct. But in years of using mine nobody has ever stopped me. Who's to know you are not recovering it or taking it from breakdown to a place of repair?
Re the cars behind campers. If its done properly then the towed vehicle uses its lights to mimic the lights on the tow car and also has its brakes activated via a telescopic ball hitch. This makes it a braked trailer which is legal to go anywhere :)
scotb
Post by scotb »
i think its the frame thats got a harvey frost jib thats illegal,not the a-frames as the rac and aa use them
scotb wrote:i think its the frame thats got a harvey frost jib thats illegal,not the a-frames as the rac and aa use them
Interesting Scot!
Can you show us what one of the jibs looks like??
scotb
Post by scotb »
Return to “General Chat Area”
