SD1 Tyres
Robrover
SD1 Tyres
Post by Robrover »
I’m needing some tyres to go on 8 x 15 inch rear Superlight rear wheels on an SD1.
Anyone know if there are any brands that do a 225/55 in a 15 inch size?
I know 205/60 is the same profile (std Vitesse) but would they go on an 8 inch rim easily?
Alternatively is a 215/60/15 viable, but this has a higher profile - would it also fill the wheel arch out better height wise?
The car's lowered to ½ inch lower than standard Vitesse height.
225 55 15 is quite a common size over here, usual suspects, michilin, uniroyal toyo all list them, certainly in R rating, fitment wise they at 8.8" wide they are within the recommended 1" of rim width on an 8" rim. If it were me I would put them on a 8.5 or 9" rim, maybe even a 9.5" rim but the last one is just really for aesthetics, it will ride and drive better on the narower rims.
Kumho in anything up to V rated
Without actually checking, I think that's the size fitted to my early E39 BMW - so available from pretty well every maker.
Robrover
Post by Robrover »
Thanks. Like 14 inch tyres, it's getting increasingly hard to find 15 inch performance tyres here beyond 205/60. Nobody seems to sell 225/55 series, most performance tyres are marketed for the big wheel Commodores, Falcons, Chryslers and Jap cars or SUVs- anything from 16 up to 24 inch.
I could do the same as many classic Mini owners are doing here - importing (10 inch) tyres direct from the UK. Or, alternatively, go to 16 inch wheels and fit 225/50/16 at the back and 205/55/16 on the front. These have a diameter of 631 mm as opposed to standard Vitesse's 627mm, so should clear the deep chin spoiler at the front. (?)
Hi Rob
If you want to import them from here and need someone to find prices and sort out shipping, or even just have a delivery address in the UK and have me forward them on to you let me know and I'll help out as bast I can.I can chase up shipping quotes for you aswell.
Have a look on Black Circles for choices
http://www.blackcircles.com/order/tyres/search
