Oil pressure relief valve piston identification .
Hi , This might sound like an odd question , but when looking down the bore in the oil pump how do you tell if an oil relief piston is actually there ? I can see a narrowing just below the threads and what looks like a second narrowing further down . I cant make out if this is the piston or just part of the bore . It doesn't want to move at any rate . It came with a used Rover V8 I bought . Thanks , Gerry .
Why dont you just undo the cover nut and see if there is a spring and piston inside??
