Group A SD1 Vitesse
Group A SD1 Vitesse
I am currently doing a University project which involves, amongst other things, creating a computer simulation of the Group A Rover Vitesse touring car engine. As such I am trying to find information about the internal dimensions and specifications of the engine, particularly the Twin Plenum induction system. I know the size of the throttle butterflys but am still searching for details on the plenum dimensions, trumpet arrangements and the size and length of the individual inlet runners. Some indictaion as to the position of the fuel injectors would also be useful.
I would be very grateful for any help or suggestions anyone can give.
Gp. A
Gp. A
Lot of useful info and contacts re the racing Rovers on here
http://www.ten-tenths.com/forum/showthread.php?t=81326
Cheers for the link. Unfortunately this thread seems a bit short on tech info but its still damned interesting; I'll be back to read it just for fun once the project is out of the way!Robrover wrote:Lot of useful info and contacts re the racing Rovers on here
Just as a point of interest, I've managed to get a basic model of the engine running using dimensions roughly scaled off photos. Its producing 350bhp at 7000rpm so revs about right but power fractionally OTT. Still not bad for an estimate!
Gp. A
You're not insinuating there may have been underhand tweakery going on are you?!v8rob wrote:depends on whether you want what was supposed to be in the engines or what was actually in the engines!
Gp. A
Yup, I'm WAVE-ing (or possibly drowning!). Not getting on too badly with it but model is still fairly basic as yet. I think it gets a whole load more exciting/infuriating as you start to attend to the details; friction, burn characteristics etc. Can definitely recommend having a crack at it though, Lewis but I know what you mean about course work and exams! What course are you doing by the way? I'm doing Motorsport Engineering at Swansea Institute.
Gp. A
Gp. A
I had the oppotunity to see some raw/un machined GrpA blocks, If that was a factory casting Ill eat my hat, every web in the block was about twice the size of a SDi block, although it had SDi casting marks there was NO WAY it was a factory block, for that reason alone, I have assumed there must also be GrpA heads kicking around as well, so the potential for extra porting must have been there, and possibly bigger valves??
Are you implying the group A SDI engines might also have been a bit dodgy as far as the rules were concerned!!!
Surley third world racing would not have used unhomolagated engines as well as body shells with "special" export suspension mountings
I am horrified at the sugestion
after all they did usr VOLVO rocker arms, and were only caught when a scruteneer looked in the oil filler hole and saw the words VOLVO on the top of the rocker armkiwicar wrote:Are you implying the group A SDI engines might also have been a bit dodgy as far as the rules were concerned!!!![]()
Surley third world racing would not have used unhomolagated engines as well as body shells with "special" export suspension mountings![]()
I haden't heard that one
what a professional outfit! I still liked the "Egyption market " excuse for moving the suspension mounts so they could fit wider wheels (specifically banned in group A) and then forgetting to tell BL so none of the drawings were submitted for homologation.
I remember hearing lots of roumers about "specially selected" head castings at the time (ie made to totally different casting patterns)
as I said, what professionals.
