My rover p5b has charging problems and uses external voltage regulator etc, which internal regulated alternator will fit the v8 engine, thinking of Lucas 18 ACR but not sure of it's dimensions and whether it will fit.
OK with the wiring differences.
Thanks Steve
alternator upgrade
- truckdoctor
- Helpful or Confused
Re: alternator upgrade
That unit is actually a very decent alternator. I had one on my early P6 3500. Later P6 used an all in one type which was nothing like as good. I assume later P5 did too.truckdoctor wrote:My rover p5b has charging problems and uses external voltage regulator etc, which internal regulated alternator will fit the v8 engine, thinking of Lucas 18 ACR but not sure of it's dimensions and whether it will fit.
Thanks Steve
To fit a later type would need wiring alterations. I'd be inclined to stick with what you have, and get it fixed. If its reg. has failed it can be fixed - it uses standard components.
- truckdoctor
Anything can be made to fit - but there are lots of variables. The shaft size changed down the line. Took me some time to find the correct pulley for my later unit. I also had to make up spacers for both the pulley and mountings. And make a new tensioner.ChrisJC wrote:I think that most Lucas alternators are interchangeable, so you might well just be able to fit the later one.
But on the early one with external regulator the wiring needs a fair bit of alteration to fit an all in one unit. Not impossible, of course.
[/img]
