Does anyone do a plenum that opens upwards?
As per title
For hotwire Efi so I can dray cold air from under the glass on the gt40
I have seen side ones, double ones, triple ones front, rear but never top.
Presume I am hoping for unobtanium!
er you could weld up the side entry hole, weld a flat plate on top and add one of these to the top of the plate
http://www.ebay.co.uk/itm/Enderle-Injec ... 3a6bdf7513
or in fact pretty well any large-ish throttle plate, Ive got a few 2 litre vauxhall ones in the garage if you want to try, there are like this
http://www.ebay.co.uk/itm/Vauxhall-C20X ... 231868a26f
best regards
Thanks for spending my money againMike!
Best off would be downdraft throttle bodies -eight of them
But as I am tight I was hoping for a ready made unit.
Perhaps time to do an edelbrock four barrel manifold and injector throttle body
Ian!
Have you not got any room to add fittings so you can run the intakes to outside somehow?
Or do the carb manifold and weld up 8 injector ports for a normal efi install ?
Is this WC one almost ready for some injector drillings ? IS that what the flat bosses are for ?
http://www.britishv8.org/Articles/IntakeManifolds.htm
Eliot has a lot of info on his site
http://www.mez.co.uk/ms12.html
mgbv8 wrote:Ian!
Hi Perry
I am currently picking up air from close to the side inlet vent.
But the gt40 is designed to draw air in from under the back glass. So much so at high speed I have started popping off the rear Perspex- pulling out the rivnust that hold it in place.
So to help reduce the pressure build up I want to draw the air in from there.
It should also be a cooler source of air
stevieturbo wrote:Or do the carb manifold and weld up 8 injector ports for a normal efi install ?
Thanks Ian
I sort of like the idea of throttle bodies -where did you get yours from?
Ian Anderson wrote:
mgbv8 wrote:Ian!
Hi Perry
Can you show us some pics Ian!!
DrDeAtH
Post by DrDeAtH »
downdraft throttle bodies would look best on the GT40 - i know they used to make ones that looked like carb bodies. but have you ever thought about a 'flying toilet'??
