Getting a slight leak from where the clutch slave cylinder meets the banjo, i have a copper washer between the bolt as per the photo, should i have a copper washer also at the other end where the leak is, you can just see the fluid seeping in the photo and the bolt is tight,
Regards,
Martyn.
Another little job i need to sort to get the Marcos back on the road.....
