Gavs supercharged V8 timebomb thread! (Eaton M112)
RobertE
Post by RobertE »
ihatesissycars wrote:This is the thing, i don't know what psi it will create in my 4.6's plenum so i need i guess to find out what it could do. In light of the last two comments i'm guessing a 9.35:1 c/rwould be good? The m112 is the blower i'll use, i can'tafford anything else so i need to build the engine around that.
Im planning on running a Vortech Centrifugal supercharger to cut down on heat, w/ a 9:1 compression(not by choice, its what I have to work with)
A 9.35:1 engine running at 8 Psi will have an effective compression of
around 14.5 .. 12 psi will be 17:1
I'd not go over 16 on pump gas(93 octane here) and thats with a good tune.. It all comes down to how well tuned the engine is.
ihatesissycars
Post by ihatesissycars »
What does everyone reccomend then?
I've been measuring this up in the engine bay and with a little inner wing bashage going on it should be do able, very snug but do-able!
Does anyone have any ideas on what i can do for a blower bypass for light throttle/cruise situations?
chodjinn
Post by chodjinn »
"Does anyone have any ideas on what i can do for a blower bypass for light throttle/cruise situations?"
Maybe a big-ass red button on the gearlever a-la Mad Max stylee lol! :lol:
Blower bypass?
Don't you stick the swiverly pate in the tube (throttle) up stream of the supercharger then you don't need a "blower bypass"
Return to “Forced Induction”
