Im planning on running a Vortech Centrifugal supercharger to cut down on heat, w/ a 9:1 compression(not by choice, its what I have to work with)ihatesissycars wrote:This is the thing, i don't know what psi it will create in my 4.6's plenum so i need i guess to find out what it could do. In light of the last two comments i'm guessing a 9.35:1 c/rwould be good? The m112 is the blower i'll use, i can'tafford anything else so i need to build the engine around that.
A 9.35:1 engine running at 8 Psi will have an effective compression of
around 14.5 .. 12 psi will be 17:1
I'd not go over 16 on pump gas(93 octane here) and thats with a good tune.. It all comes down to how well tuned the engine is.
