It wouldn't matter if the previous owner used the right size key!stagcar wrote:
why cant they just use bolts like every other fly wheel i have taken of still that's progress for you.
3.9 rebuild ready for blower questions here we go again :)
- topcatcustom
Your not wrong there tc still I am to blame for screwing up one of them and my key was a very tight if not hammer fit. I think there just made of rubbishtopcatproduction wrote:It wouldn't matter if the previous owner used the right size key!stagcar wrote:
Derek
Rust rust and more rust
Just done this spacer routine, same trouble, correct key and they just round as soon as you look at them, drilled the heads off and the remainder screws out with your fingers, Jim in Ireland does a great price on genuine replacement socket head screws, will ship for next day, give him a call. Really nice guy.
Alan
Alan
Thanks Alanbigaldart wrote:Just done this spacer routine, same trouble, correct key and they just round as soon as you look at them, drilled the heads off and the remainder screws out with your fingers, Jim in Ireland does a great price on genuine replacement socket head screws, will ship for next day, give him a call. Really nice guy.
Alan
I have been having a go at them tonight I need to cone back with some good quality drills the one I have are rubbish and went blunt sin no time
I will win this battle
Derek
Hi all,
Strange thing i have just pulled the pistons out and all the rings look to be in one bit.
The oil rings seems to be stuck in the grove and will not move this seems to be the case for all the pistons tho
So i have no idea what has damaged the bore's.
I now have a good ish set of drills so i am going to attack the crank spacer this week end
Also whats the best way to pull the little oil galery plugs out?
Derek
Derek
- topcatcustom
topcatproduction wrote:Unscrew the 2 threaded ones (can be bloody tight), then you can get a rod through to knock the ones at the other end out. Have you found oversized pistons yet for when you have it bored?
Nice one TC that will make short work of them. i dident think of that..
As for the pistons i was going to get a set from realsteel cost about £135 for the plus 20tho 9.35 CR
I was also looking at stroker kits but there out of my price range at the moment TBH
Thanks again
Derek
- topcatcustom
Forget the stroker kit, keep it simple. When you start using different crank, rods and pistons etc you will have loads of checking and machining to do to get them all to fit and work properly, plus take my word for it- you can have PLENTY of fun with 4000cc's of blown V8! Simple, cheap and cheerful is the way to go
TC
Your not wrong TC fun at the end of the day is the name of the game.topcatproduction wrote:Forget the stroker kit, keep it simple. When you start using different crank, rods and pistons etc you will have loads of checking and machining to do to get them all to fit and work properly, plus take my word for it- you can have PLENTY of fun with 4000cc's of blown V8! Simple, cheap and cheerful is the way to go
And cheep and cherfull is also nice.
It will be good to have what will be an as good as new engine aswell I think most of the v8 stuff I have ha in the past has been well worn.
Derek
Have a look at the state of this
Hi all
Just finaly got the engine back +20 and honed and it looks nice
so i started to pull some parts of the old 3.5 that had lack of power and was smokey and found it has been painted on the inside
Whats more the oil pump had red paint flecks in it and when you turn the old engine by hand it squeeks
so it looks like the end of the road for this old goat..
any way for you amusement here are some pics of the inside paint
As you can see its not a bit of over spray and its even on the valve springs....
it looks well worn looking at the state of the timing chain
any way when i finaly get the engine out i will start the 3.9 asembely
Many thanks
Derek
Many thanks
Derek
Stupid question number 2 :)
Hi thanks for the advise on the grease
My next question is about ARP studs
I am using arp studs on the mains and i am not sure if i should use thred lock on them or not?
Many thanks
Derek
Many thanks
Derek
clean the washers, nuts and studs, lubricate lightly with the correct thread lubricant, same with the threads on the studs, do to the correct torque settings in 3 stages, finger tight, about 1/2 finished torque setting final setting clean off any thread lube that gets squeezed out with a clean dry cloth.
