Eaton M112 Data / spares / parts??
You could use an M90 on a 3.5 (again using your figures - i will try to check them for you)
But I would use the 112, as it gives more scope for upping the capacity.
The Original Tom
Post by The Original Tom »
The M90 does look better for low boost, but if I increased it even a bit it would become less efficient, and we all know that once I start fidling with boost, the only way is up!
Unfortunately though, the contact I had that was trying to shift his M112 cheaply has had a change of heart, so it's going to be a long time before I'm able to afford to do this now... Sorry for the wasted time but it's quite a good tech article any way!
Return to “Forced Induction”
