New Injectors?
cheers mate,
http://www.ebay.co.uk/itm/8-Siemens-Mot ... 3f07fae503
so they will be ok and a direct replacement then?
as need to order this week as Phil has confirmed the injectors maxing out so before I go any further with the racing I need to get these sorted,
- daxtojeiro
- Forum Sponsor
Toni,
just remember, when you do fit your new injectors, you will change the req_fuel setting appropriately, but the whole VE table will need re-tuning.
In theory this shouldnt be the case, but it always is as injectors opening time characteristics change at different opening times, and the spray pattern will be different.
So dont just jump in it and start driving as you had been, start by logging it and keep out of boost until you get a feel for what needs changing.
thanks
Phil
thanks
Phil
- SimpleSimon
I presume your hinting inj dead time Phil?daxtojeiro wrote:Toni,
thanks
Phil
fuel pressure is 43psi
I bought mine from a company call Trigger Wheels and they are a UK company, not a huge range but they do deliver quick
http://trigger-wheels.com/store/index.html
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
