New Injectors?
cheers mate,
http://www.ebay.co.uk/itm/8-Siemens-Mot ... 3f07fae503
so they will be ok and a direct replacement then?
as need to order this week as Phil has confirmed the injectors maxing out so before I go any further with the racing I need to get these sorted,
Either will be fine, just curious as to why the different part numbers and pictures of different injectors ?
daxtojeiro
Forum Sponsor
Forum Sponsor
Post by daxtojeiro »
Toni,
just remember, when you do fit your new injectors, you will change the req_fuel setting appropriately, but the whole VE table will need re-tuning.
In theory this shouldnt be the case, but it always is as injectors opening time characteristics change at different opening times, and the spray pattern will be different.
So dont just jump in it and start driving as you had been, start by logging it and keep out of boost until you get a feel for what needs changing.
thanks
Phil
Can't you just increase your fuel pressure?
The 044 should have enough headroom shouldn't it?
Depends how much headroom you have or need. But it would be a free option.
SimpleSimon
Post by SimpleSimon »
daxtojeiro wrote:Toni,
thanks
Phil
I presume your hinting inj dead time Phil? 8-)
fuel pressure is 43psi
And how much more fuel do you need ?
Wind base up to 65 or so. At 10 psi boost, that's still only 75psi tops
Spongo
Post by Spongo »
I bought mine from a company call Trigger Wheels and they are a UK company, not a huge range but they do deliver quick
http://trigger-wheels.com/store/index.html
Range Rover 630R or otherwise known as the Money Pit
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
