Power Resistor Pack
ozrover
Power Resistor Pack
Post by ozrover »
Does anyone know if there were different specs for these for the flapper efi or are they all the same?I have one from sep 84 with one part number and another from april 85 with a different one.Both VDP EFI's. Curious to know if they are different and how so.Any info appreciated.
Regards Doug
ramon alban
Re: Power Resistor Pack
Post by ramon alban »
ozrover wrote:Does anyone know if there were different specs for these for the flapper efi or are they all the same?I have one from sep 84 with one part number and another from april 85 with a different one.Both VDP EFI's. Curious to know if they are different and how so.Any info appreciated.
Regards Doug
Hi Doug, Not easy without the part numbers but notwithstanding that a prior owner has substituted a different unit on one of your cars, all 1982-86 Efi rovers had the same spec unit.
Test the resistance of each element for 6 ohm + or - 1 ohm as per this diagram.
If they meet the spec, they are OK.
Ramon
http://www.vintagemodelairplane.com
