AP Clutch Listings
Was this info useful?
YES?
5
100%
NO?
0
No votes
Total votes: 5
AP Clutch Listings
Thanks to marki for making this one document from the long list of pages i found,
BEWARE this is a big file,
http://www.v8forum.co.uk/docs/ap_clutches.pdf
Page 1 -> CARBON / CARBON CLUTCHES,
Page 18 -> SINTERED & CERAMETALLIC RACE CLUTCHES,
Page 49 -> SLAVE CYLINDERS, BEARINGS & STUDS,
Page 53 -> FORMULA CLUTCH KITS AND FLYWHEELS,
Page 56 -> HIGH PERFORMANCE CLUTCHES,
Page 63 -> HIGH PERFORMANCE CLUTCHES, Application List
Hope this is of some use to every one,
rover v8 is page 71,
tvr page 72
Back up online again now.
I'm using a CP2394-60 cover & CP2346-4 friction plate with a spec of 339lbs/ft of torque, not sure how much longer it may last mind you :lol:
anyone mix and matched any of the AP clutches with any success?
BISH V8
clutch
Post by BISH V8 »
That's the same spec I've been advised, how do you rate it?
Current project
1972 mgb v8 4.6 roadster
not bad clutch been using it for a few yrs now but need something a bit stronger once I go racing again.
BISH V8
clutch upgrade (Tony)
Post by BISH V8 »
With regards your clutch you used Tony CP2394-60 Cover and the CP2346-4 Driven plate, did you have the round nose bearing and also did you have any problem fitting to flywheel, I have been on to AP a dozen times and every time I ask a question I get a different answer, the latest from the technical side is that they don't know it will fit!! they are trying to sell me me the kit cp2000-13 but that only gives you a max of torque of 270llb, I am pushing 315lb of torque so wanting the 339lb uprated clutch. This is only a big issue because V8bloke (Mark) had such a hassle with fitting kit, it was wrong they ended cutting something off, the driven plate was to thick meaning it would have never worked, I think the driven plate thickness should be 8.38mm and I believe marks was 8.89mm.Its a hard life all I want to do is order a kit which fits, costs are 450 quid so I want it right...
Current project
cluitch fitted straight on with no problems, and I think its the round nose bearing I have mate,
