Biva test
ford100ev8
Biva test
Has Any 1 who has modified there car took it for a biva test , I have seen the points table , but there seams many cars around that wouldn't keep there reg on the points table , any info would help thanks
- richardpope50
- Gold Member
Well yes but I assume this is not what you mean. All kit cars go through the Basic IVA as did mine and to be honest, the points regarding the registration number is minimal. It's the rounded edges and similar requirements that are the problem for us although usually passed on a re-take.
Where do you see the problem, may I ask?
Richard.
ford100ev8
ford100ev8
is it previously registered as a modified car (hot rod) on the registration documents or will this be the first modifications that take it away from a stock "Numbers matching" (as it left the factory) car? This is of course as far as the registration documents are concerned so if it has been running a Ford FE since 1965 but no one bothered to tell Cardiff then it is still original as far as they are concerned. . .
What I am getting at is that if it has a non original engine, gearbox and back axle, and all the paper work was up to date to cover this before the BIVA came in then you will be OK to change those items, likewise if the firewalls were modified to fit then you should be OK if you need to change them further. However if the paper work does not reflect this prior to the introduction of the test then you will have to go through the procedure and tests.
best regards
best regards
ford100ev8
- richardpope50
- Gold Member
I think some people think there are a few grey areas here as you are allowed to change the engine simply because if your engine blows up, you need a new one. In addition, you do not have to have the same one / type but if you take the IVA test then the engine will be tested for emissions on the age of your engine. However once tested, the engine emission classification will stay even if you change engines afterwards.
Its all really regarding the chassis. As all (well almost) kit cars have a new chassis then you need an IVA test and you have to get a new registration. If you keep the same chassis but modify it, then I understand that you also then need an IVA test. Not sure if you need a new registration as well as the rules seem to say if it is currently registered it does not.
I know that even fitting a Ford Type 9 gearbox into an MGB (a common mod) requires making a modification to the chassis (the tunnel) so strictly speaking requires a test. It is not because you have changed the gearbox.
So I agree and I think the answer as the chassis has changed (after IVA introduction as per above post) it sounds as though you need a test - then it's down to the IVA manual rules. I do not think you need a new registration, though.
Richard.
ford100ev8
