Uncobra, the V8 FrankenHealey
kev_the_mole
Wooohooo! At last! Everything has been held up for the last 4 weeks due to the non-delivery of the new rad. It seems that there was a serious accident(????) at Serck Motorsport which stopped everything for a while.
Old rad (which did not have to contend with the new steering column, rack and re-sited oil cooler)
which won't fit in this gap now!!!!
......but this will fit it or it will mean a refund!!!!
It's an engine Jim.....but not as we know it
kev_the_mole
.... the rad she is in and loadsa work with cardboard templates and tinsnips means the ducting is half finished....
...the bad news is that the engine being further back and the rad further forward means that the original hoses are just an inch too short....
...bugger
...bugger
kev_the_mole
kev_the_mole
kev_the_mole
kev_the_mole
kev_the_mole
Loads of small things now to be ticked off the list
But the boot's finished apart from a clean up! Everything's wired, tank pressure tested, tank return for the winter fuel injection project, battery isolation switch, low pressure fuel pump etc etc etc
kev_the_mole
As the oil cooler is effectively blocked by the front shroud and therefore gets no airflow it needed a cooling duct and here is the result
Now look hard at the photo, consider the headlights as eyes, the grille as the nose and the oil cooler duct as the mouth. Yes Folks, I think we have an extra from Pixars 'Cars' animation.
....and underneath
[/img]
....and underneath
[/img]
kev_the_mole
kev_the_mole
