Does the ECU 14CUX need to be chassis Earthed?
Well pretty much as the title says
The ECU on my 40 is mounted on a fiberglass bulkhead.
Should it be earthed though the chassis mounting bolts? (If so I can run an earth to it)
thanks
r2d2hp
Post by r2d2hp »
Mine sits in my glove box and is not bolted to anything and works just fine.
mine was earthed to the back of the engine block, as on the sd1 efi there is a stud for the ecu earths,
GreenV8S
Post by GreenV8S »
There are earths in the loom, but the ECU case itself doesn't need to be earthed.
Peter Humphries (and a green V8S)
Thanks guys - the cubby hole bit does it for me!
I also just received a replacement ECU from fleabay and will be trying it to see how i compares t my hipped version!
cheera
