8 PK SUPERCHARGER PULLEY.
j.johnson23
Post by j.johnson23 »
Does anyone know of,or has a crank damper or pulley that`s around 6 inches in diameter?
Its for a little experiment I am planning involving a v8 and an m112 supercharger.
6+7pk pulleys are easy to come by but 8pk ones seem a bit thin on the ground.
I`m based in the uk(west midlands).
I built a supercharged 1600 cvh ford with a blow thru SU carb a few years ago and it worked really well,now I have a tr7v8 with a low comp engine ive just rebuilt and want to try it again on a bigger scale.
Is this for measuring up purposes? I have a 6 1/4 Small block chevy sfi damper off my engine at the moment as it is stripped for winter. I could lend it to you for a short while, I would need it back as it is the one for my engine! and I might be driving close by on saturday depending where you are (west midlands is a bit of a wide area.
Mike[/b][/u]
j.johnson23
Thanks for reply but I need something permanent.
By 8pk do you mean an 8 groove pulley?
What engine is this for?
im only running 7pk on my supercharged v8
kev_the_mole
Post by kev_the_mole »
I can make you an 8PK pulley but setup times really jack up the prices on a one-off.
j.johnson23
Thanks for replies but i think it may be sorted now.
Return to “Forced Induction”
