Hi all readers,
Been thinking ( a dangerous act ... I know ) about fitting a AFR meter.
I don`t want a permanent fit meter more of a portable job in the sense making the oxygen sensor a permanent fit and the remaining electrical system in its own box so I can hook up to it when required. I want to find the best settings on timing / carb. e.t.c.
Point is assuming this a workable idea where best to fit the oxygen sensor, inlet manifold or normal fit in exhaust?
I have no ECU or any kind of engine management system on the car.
Polite suggestions or ideas please.
Many thanks ... Mike
AFR METER
