Getrag - Rover V8 Adaptor on a budget?
Hi all,
I've come to the conclusion that I need to swap my ZF HP22 box for a manual. I've been looking for LT77 but they are so expensive!
My budget is quite small (£300ish) but I wondered, how easy is it to make an adaptor for a Getrag BMW box to the Rover V8? I know there are companies that sell ready made adaptors but I've also seen people make their own with very little, if any, machining. Admittedly, the links I found were not for the BMW box, but I did read on here that some of you guys have got 635 boxes fitted.
So, my questions are:
If I went the getrag route would I need the SD1 flywheel, clutch (with a different plate), hydraulic release arm and bearing?
What BMW is the best source of box? Year etc?
Also, has anyone got some drawings/photos of conversions already done?
Thanks for your time guys!
Ben
Ben
- topcatcustom
Muscle-Manta
I used a Getrag 265 box from an Opel Monza/Senator on a modified SD1 bellhousing. The mounting flange on the rear of the bellhousing was machined off, an adaptor plate was welded to the rear of the of the bellhousing to mount the Getrag.
I used the Rover flywheel and cover plate. The friction plate was Jaguar as the input shaft on the Getrag box is 1 - 1/8" 10 spline. The release arm, throw out bearing and clutch slave are all Rover.
Muscle-Manta
I no longer have the car so can't take any measurements for you. However from memory the plate was 8mm thick.
When you acquire a g'box offer it up to your engine with the input shaft located in the spigot bush in the rear of the crankshaft. now measure from the mounting flange on the gearbox to the bellhousing mounting flange on the engine. This measurement will give you the total length of the required bellhousing.
Muscle-Manta
Could I do an adaptor the other way around? i.e. space it out from the block 10mm?
Like this:
http://www.motorswaps.net/forum/showthread.php?p=4106
Ben
Like this:
Ben
I fitted an LT77 to my Rover P6 using the bell housing off the BW35 auto box.
I had a plate made up that mated the box to the round hole in the bell housing with the correct thickness to set the input at the right depth.
I used an SD1 master cylinder mounted to the bell housing to fit the throw out lever via a hole machined into the side of the bellhousing. Clutch and plate are SD1.
When the LT77 died, the same procedure was used to fit a 4spd overdrive Shaguar box.
Interesting. Thank you. Annoyingly I sold a BW35 bellhousing last year!unstable load wrote:I fitted an LT77 to my Rover P6 using the bell housing off the BW35 auto box.
I haven't seen the Getrag box before, so the BW housing may not be suitable. My point was rather to illustrate that with a bit of lateral thinking, you can achieve your goal.
I was fortunate in that the guy that helped me was a fitter and turner instructor at a training school so all I had to do was supply materials and labour and machining was free.
