'73 Blown Ford Capri V8
V8 Only Please,
JP.
Post by JP. »
1973 Ford Capri 1600 GT :roll:
Rover Sd1 V8 3500cc.
Reduced compresion from 9.35cr to 8.65ce with RS Composite headgaskeds.
Offenhauser 360 Equa Flow intake modifiet to single plane design.
Magnacharger 110 supercharger, 60% overdrive 6.2psi calculations.
Holley 465 cfm modifiet to aprox 520 cfm.
Holley Megascoop.
MSD 6 AL ignition box, MSD Pro Billet distibutor wo vacuum. MSD Super Conductor leads. MSD Blaster II coil.
Twin 2 ¼” exhaust system with balance pipe, Hooker Aerochamber 441 cfm mufflers.
16 row oil cooler with B&M stat, remote oilfilter and an MGB V8 high presure spring in the oilpump.
Viper Huricane camshaft.
Facet fuel pump with King filter.
Mc Leod 10.5” street/strip clutch on stock refaced and balanced SD1 flywheel.
Transmission : Rover LT77 5-speed.
End ratio : 3.09 : 1.
Very tidy setup 8)
barginbucket
Post by barginbucket »
top bombing,very nice
nothing new there then
Return to “Your Cars”
