I had previously been playing with the fuel pressure regulator and it was set to approx 5 psi which I believe should be OK for a STD 3.5.
I took the car out the next day (which was hotter) after upping the pressure to 6 psi and found the engine did not overheat even though I was in traffic.
I have never had this problem before and I am assuming it was the carb getting too hot and vaporising the fuel in it?? or could it have been some dirt?? I have regularly had the car running with the fans on and never had this back firing.
Am I correct in my assumptions and would increasing the fuel pressure help a vaporising carb?
I have had the headers Ceramic coated inside and out so the under bonnet temperatures should be lower than normal.
Does any one have experience of fitting bonnet louvers / vents on MGB's and do they work? I would rather not as I would like to keep the original bonnet looking standard.
Any remarks would be appreciated.
Regards
