transmission fluid dribble gm180 autobox
righty ho folks im getting a bit fed up of the little leak i have on the gearbox, at first i thought it was just the oil filler/dipstick seal where it meets the box but after sorting that and closer inspection i can see that its actually running out of the square opening on the bell housing, is there a seal at the front of the box that is prone to leaking and can be replaced/
cheers
chris
cheers
chris
softdash3.9
It looks like the outer bolts hold the bell housing onto the main case, the inner ones will be holding the pump. . unbolt the outer ones and I suspect the bell housing /front cover will come away with the pump attached. you may have to hold the input shaft in place as you remove it but it is not "loaded with springs!
You might find this a help
http://en.oto-hui.com/a3396/[gm-training]-automatic-transmission-4l30-e.html
it is the 430L but I think that is just an electronicly controlled version of the Th180.
One common reason for failure of that seal is damage caused by removing/replacing the box with the TC still in place.
Since you've got to do some stripping to change the seal, examine the pump carefully at the same time. They are often the first thing to fail with high miles.
[/img]
