Dilemna
Lewis
Post by Lewis »
Looks serious :twisted:
I hope you swap those rocker covers for something slightly more attractive, I mean, they're not bad but they look like something off a tractor :lol:
Those ports look good though......obviously well-proven and thought out!
ihatesissycars
Post by ihatesissycars »
They're a bit industrial aren't they! I'm stuck with them though as normal rover covers or anything from anything else won't fit. I was thinking of a crackle black finish?
Lewis
Post by Lewis »
Aye that might do the trick, some shiny breathers as well just to break it up!
pitsnow
Post by pitsnow »
Is RS suppling those heads with a custom intake manifold?
The intake ports are different to anything I know.
ihatesissycars
No you use your own modified to suit. Its well within the realms of grinding and epoxying. I might even give the itb's another try with these.
ihatesissycars
Wooooo they're here!
I'll take some piccies tonight. First thing i noticed though was how much lighter they are!
Post by ian.stewart »
:D :D :D , What CC are they gav????
THE SMOKING GNU
ihatesissycars
Mine are 27, the smallest chamber they did which i will also add is a much better shape.
ihatesissycars
Here they are.
Chamber + valves
Rocker shaft end pedestal
Ports
I hope they're worth the expense. . . .
JP.
Post by JP. »
Whats your impression on these heads versus the other brands.
Please share your opinion as youre the first one to share.
I am very impressed by the pics and I am gone talk with RS if these heads are suitable for our 3.5.........................................blown engine.
( commin over to the Uk to vissit Classic Ford show so will make a litlle D tour to RS :wink: )
ihatesissycars
I'm no expert!
They well made, no rough bits, all good in that dept.
The ports are small but they flow well enough to put out 330ish hp on a 5.0 so obviously capable.
The rocker covers look better in the flesh too!
The covering letter i have says no way for 3.5's but they will be bringing out a another version for the 3.5's plus i think they'll be constantly updating the head too as time goes on.
I'll wait and see what the engine goes like which won't be for a while yet as i have alot more other bits to get yet and now thanks to these monies non existant! I'm also talking to the chap who bought my itb's to see if he wants to sell them back to me as he may be getting a supercharger for his TreVoR and they'd compliment these heads well i think, i just hope i can master them, if i get them that is. . . .
katanaman
Post by katanaman »
interesting lumps in the bottom of the inlet ports. Its more normal to have them in the top to spread the air round the valve guide. Zero room for bigger valves by the looks of it and port matching with the inlet will be interesting with those shapes, surprised they don't do an inlet to fit as the shapes are so different. Nice looking heads though and there looks to be room for mods if needed.
ihatesissycars
Well ref the inlets i'm certain a standard, untouched inlet manifold could be ported to suit as the ports really aren't that big!
katanaman
Post by katanaman »
I was thinking you would actually have to do some welding to the manifold to fill in where the curve is, where the standard is more rectangular without the corner missing. Course the port could be taller but I cant tell that from the pic. Stick a gasket on and you will soon see. One thing is for sure there must be an advantage to that shape or they wouldn't have done it.
HairbearTE
Post by HairbearTE »
Marki the bumps on the port floor are certainly very interesting. Perhaps they serve to guide the airflow arond the stem? or maybe by increasing the surface area of the short turn by introducing these bumps they have managed to reduce seperation from the port floor by the inlet charge? Anyway I think the most obvious improvement over the rover design is apparent in the topmost of the pics Gav has posted...
Return to “General Chat Area”
