car wont start,i have spark and fuel,dont understand it
ok i just fitted a new dissy as my old one died,now iv been trying to start the car and iv got spark and when i take the plugs out they stink of fuel but i cant get the car to fire up,
if i take the two relays out the efi loom then turn it over car car backfires a lot so its definatly gettin fuel,but when i put the relays back in i still cant get it to start,
could it just be flooded or timing really far out,
Agree with the above, also don't assume that the ignition timing is right.
Peter Humphries (and a green V8S)
3rd'ed. Fuel + spark + backfires a lot? Maybe timing, but I'd bet it's the firing order - check the leads are in the right place first. I've sworn I had it right myself before - checking against Mr Haynes' finest - but it was completely backwards...
VEMS New Zealand Limited
Versatile Engine Management Systems : World Class Technology. Global Support.
For UK sales, visit VEMS UK
Putting the dizzy in with the shaft 180 deg out causes it, its nothing to do with the oil pump. It might not be but it does sound like it. Just because the body is in the same place doesn't mean the timing is the same when you have removed/replaced the dizzy. Its so easy to put it back a few teeth out or if the engine has been moved a full 180 deg out. Just follow what I said above and you will soon see where you are, you can then move the leads to where they need to be.
i followed it as much as i could but i cant get the timing in the right place cos the amp hits the engine so the dissy wont turn any more,
il take the dissy out n put it back it moving the shaft 180 deg round,hopefully that will fix it,cheers for ur help people
wouldnt have figured this out without you
and just for reference,
passengers side (n/s) is cylinders 1,3,5 and 7
drivers side (o/s) is cylinders 2,4,6 and 8
with cylinders 1 and 2 being the forward two cylinders
To set the timing from unknown, I remove the drivers side rocker cover, turn the engine so both valves on no. 6 are open equally. This means no.1 is at TDC on the firing stroke.
Then I stick in the dizzy so the rotor arm is pointing to where the no. 1 lead is exiting from and so the little magnetic spider is pointing to the pickup. Then put it all back together and away it'll go!
