Single Turbo Rover V8 3.5 Triumph TR7 Build
thewedgeshop.com
Post by thewedgeshop.com »
The full throttle issues was caused by having a restrictive carb hat on it. Changed that out and it runs great. Will get it back to the dyno shortly.
Had to cut a hole in the hood to get the new carb hat to fit, this is a short term solution and I will come up with something a bit more astheically pleasing shortly.
Here is a quick 3rd 4th gear pull. Car runs strong and am expecting 275-325whp when I get it back to the dyno.
http://www.youtube.com/watch?v=GSAYZ_Ls ... ature=plcp
Clint
www.thewedgeshop.com
Rover V8 Performance
http://goo.gl/aDa3L
topcatcustom
Post by topcatcustom »
That sounds bloody good!
TC
Good stuff...but will 4psi be enough lol
thewedgeshop.com
Car is currently running 11psi through all gears. Plan to move it up to 15psi once meth injection is installed.
Should have dyno numbers in a few weeks.
Clint
http://goo.gl/aDa3L
JJMclure
Post by JJMclure »
Nice! sounds like someone enjoyed the drive in the video!
don't nibble on the barrel, pull the trigger!
DaviesDJ
Post by DaviesDJ »
Amazing guys, love the on on the turbo:-) ay figures on BHP yet at all???
thewedgeshop.com
No numbers yet. I am going to square a few small things away before I bring it back to the Dyno. Should have numbers in a few weeks. I expect 275-325 on 11-15lbs of boost.
Clint
http://goo.gl/aDa3L
thewedgeshop.com
Car made 278whp & 305wtq @ 10psi. Still has more in it with some added boost and timing.
Video below.
http://www.youtube.com/watch?v=_HJI_wSx ... e=youtu.be
http://goo.gl/aDa3L
Return to “Forced Induction”
