Hi all, any brake guru's care to help with a big problem I have in sourcing rear discs and calipers to fit to a Salisbury HA axle originaly fitted to a Jensen, thats going into a Rover p5b coupe as it has a 2.8:1 limited slip diff. As these original parts are formidably expensive I'm looking for alternative parts that may fit or may need a bit of modification.
As you can imagine trying to find parts amongst so much choice is bewildering but have seltled so far on Mondeo parts, any thoughts please.
Here's a few pics of the unit so far.
Home made hub puller removing the tapered joint.
If dimensions would be helpfull then its all available, just to help , stud pattern is 5 on 5 etc.
Thanks so far, Steve
