Didnt go quite as well this weekend with a rained off Sunday. Monday was better and the track was getting better all day.
But i had the return of the dreaded backfire on a NSCC qualifying run. The explosion from the plenum completely blew apart the air filter and even blew the 72mm plenum sleeve out of the plenum intake
So on the following 2 runs i used only 1 stage each. I used stage 1 with a 70 shot at full throttle and ran 12.2 @ 114 and the wideband was in the 13's so maybe a little leaner than i would normally like. On the next run i used stage 2, a 100 shot on a pushbutton and ran 11.9 @ 119 with the wideband dropping into the 10's so all fine there.
But then i had a tough race to face and had to deicide wether to risk using both stages......
Here is the in car video
http://www.youtube.com/watch?v=DU2-o2uGQG0
Same damage as before but it all went back together and i drove the car home. it seems fine but i will at least pull theplugs and do a comp test etc.
