Hi All
Mate of mine has a cracked block in his boat,yes I know its not a car but need help.
Anyone know of a specialist cast iron repair company or has anyone heard of the lock and stitch system for repairing blocks.
This is not a wind up Coops, really do need help.
Anyone?
P
Cracked block
I googled this as we had a company out once too repair a power press
http://www.google.co.uk/search?q=cast+i ... 14&bih=616
Has he thought of trying kalimex ?
http://www.kalimex.co.uk/
So thats where it went !
Hi Paul
I was pointed at a company who did it in my area by westwood liners http://www.westwoodcylinderliners.co.uk/, they were helpfull to me, I suspect they can point you to someone in wour area.
There was an article in carcraft a few months ago on block repair, focusing on welding, might be of use have a hunt it should be here http://www.carcraft.com/techarticles/index.html.
It can be done, but involves a lot of preparation. You will also need to line bore the crank and cam after and rebore to get it all squared up again.
You may get off cheaper buying another block. What make is it?
You could try one of the epoxy sealers, but if it's a single motor vessel, I would steer away from that option, it cracked for a reason, and that needs investigation.
Hi Guys
Thanks for the help with this one.
Will pass on the info to him.
Its a Yanmar marine block and they have thin wall casting to keep the weight down so I too think that a new short motor or a secondhand one is going to be his best option.
Poor bugger had just sold it aswell subject to sea trial and now this has happened.
Thanks again
cheers
P
Thanks again
cheers
P
