auto to maual box what do i need
Hello 1st post for me!
have a landrover 110 v8 obviously 3.5maual
want to fit larger cc engine whicch are auto,s whats needed ie fly wheel/clutch etc any thing else for manual box
thanks Dava
thanks Dava
Hi Dava
Welcome to the Forum
You will need to change the crank spigot bearing, the pedal box, plumb in a M/C and various hoses.
You may need to change the gearbox cross member and maybe the speedo drive and cable but I am sure that other's with far greater knowledge than me will also add anything that I have missed or put you straight and me in my place.
cheers
P
cheers
P
I am not sure I understand the question!!!
Are you saying you are going to get a later engine from a vehicle with an auto transmission and put it into your manual car, and you want to know what you will have to change on the engine?
If that is the question, what is the new engine coming out of, what CC, what fuel injection system etc etc. is it?
thanks alot
Got a rangey flywheel just need spigot bush then, now just to find an engine.Thanks for the info not as bad as i thought
