Guys, I've been wondering, has anyone made a pully so that you can run the short P5/P6 waterpump but keep the SD1 bottom pully and aulternator? Basicaly (as far as I can see) all it would mean is to have a dish machined in to the pump pully to bring the drive inline with the bottom pully...... has this been done before??
Jono
SD1 pully conversion for shortwaterpump??
It's not the weight of the pulley but the force exerted by the belt you should be concerned about. The further away from the bearing the greater the force on the bearing.
Having said that I reversed and spaced my serp pulley to line up with my supercharger pulley. I did this knowing it would greatly reduce the life of the waterpump. I have since changed the pulley arrangement back to standard (for other reasons) but it ran fine when it was spaced.
I figured the water pump bearings are also designed to hold the viscus fan so 'should' be over engineered!
