Which needles for SU carbs on a Rover 3.9 ?
Hi , Anybody know which needles would work best on a Rover 3.9 fitted with SU HIF6 carbs ? Hope someone out there can help , thanks .[/b]
Putting K&N cone filters on the carbs using the existing "stubs" from the normal inlet set up (ie what is left when you have removed the existing plumbing and filters) reduces power even when you have rejetted. the standard set up with paper filter is much better.
There are two reasons for this,
1 the stubs end directly over the exhaust manifolds so you end up feeding the engie with hot air
2 The remaining stub has no flair or radius at its end, this flows far worse than the tube and airbox.
