Megasquirt fault, any users on here?
- ihatesissycars
I depends where your measuring it.
I would expect to see 12v on the harness side of the connector for each coil channel going to the MS unit with the ignition on - assuming your coils still receive 12v feed with the MS unit (and hence the mail relay OFF) disconnected.
[hmm, not sure that makes sense]
I helped someone out the other day with a 4 banger, using wasted spark. the two spark channels from the megasquirt to the coils were via spade connectors - so we could just pull them apart and check that we had 12v on each one. Turns out he wired the coil packs up wrong.
- ihatesissycars
bill shurvinton
- Getting There
- ihatesissycars
Indeed. remember the coil is just a bit of wire, so 12v at one end will result in 12v at the other end.r2d2hp wrote:It means you coil in knackered.
Have you tried measuring the resistance between center pin and the 2 outside pins.
So the 12v feed gets split between the two coils and returns to the MS. You should see 12v at the gnd end when just supplying 12v to the feed.
12v-------------CCCCC--------gnd (or to ms)
:__CCCCC-------gnd (or to MS)
- ihatesissycars
No no no this is the wiring plug i'm measuring unplugged not the coil itself.
With the plug unplugged and ign on 12v is in the middle pin and 0v on the outer pin. Thats should be correct i believe.
I've checked resistance of the coil and thats fine. I have two coils from different cars so i'd be surprised if i picked two that don't work.
I havent had the lot fitted and pluged in and checking to see if i have 12v on the outer pins yet, i should check that also i guess!
bill shurvinton
- Getting There
- ihatesissycars
- ihatesissycars
Don't see why not, I've done it myself with a normal coil in the past to check it out.ihatesissycars wrote:Would it be ok to ground one of the coils outputs with a switch inline and see if i can get them to spark?
Have you wired in a 25uF capacitor on the input to the coils? This will stop it working if it's wired in series instead of parallel.
Next thing is to double treble and quadruple check the earths. IMO you can't have enough of a good earth
Just in case you're getting a bit fed up; keep going, it's a steep learning curve and a bit of a bastard to get going but once it's running right you'll never go back to a normal setup. It's main problem is that there is so much to configure, which is also it's main asset as you can do almost anything with it.
Kev
- ihatesissycars
