Hoping you can help, gone and confused myself with too many crankshafts in the garage and can't remember how to put back together ... even got three v8 manuals and still not absolutely sure.
Anyway, here goes ... its a manual gearbox goning on a 3.9 engine, changed from a 3.5. Does the fly wheel bolt straight on to the cranks shaft with out any spacers?
In a box which I used to keep associated stuff together is a spacer or adapter with six bolt holes which line up with those on the crank shaft, it also has four (from memory) other threaded holes. Also in the box is a thin plate, think its called a reinforcing plate. The bits in the box, are they for an auto box?
Thanks,
BBT.
flywheel / crankshaft question.
Bobbybedtime
sOUNDS A BIT LIKE A DISMANTLED FLEX PLATE ???
dAMN THIS STICKY CAP LOCK KEY....
Bobbybedtime
Re: flywheel / crankshaft question.
If you're going manual you won't need the spacer/adapter you mention having, so if you want to put it to good use "koopsterman" on this very forum is in need of said item.Bobbybedtime wrote:In a box which I used to keep associated stuff together is a spacer or adapter with six bolt holes which line up with those on the crank shaft, it also has four (from memory) other threaded holes. Also in the box is a thin plate, think its called a reinforcing plate. The bits in the box, are they for an auto box?
Thanks,
BBT.
